Define Report
Define Report group enables user to perform report actions in just one click.
The following options are available in Define Report:Figure 1.
New Report
Create new document or presentation report directly with the help of this one-click option.
Template
Load report structure from a report template and save the report template with the help of this one-click option.
Run
All items marked for execution are executed, and the output and previews are generated.
Export
Export and synchronise report. Synchronize the exported report with new changes in
the Report structure or content.
Note: Synchronize activates after you export a
report. The required file to synchronize can be saved and selected from any
location.
