2024
Use the Model Checker to configure solver validity checks, modify and create new checks and corrections, and fix modeling issues in an automatic or manual way.
Supported default checks organized by solver interface.
View new features for Altair HyperWorks 2024.
Use the Model tool to quickly run solver-related checks on all/selected entities in the model and apply auto-correction where defined.
Provides a variety of options for working with the Model Checker.
Create new checks and corrections, and edit default checks and corrections.
Organize new and existing checks inside of a user-defined Check Folder.
Save configurations for future use, import existing configurations into your current HyperMesh session, or append configurations on top of existing configurations.
Find all entities in your model that failed the active checks in the Model Checker.
Use this sample script to run the Model Checker in batch mode.
Check contacts, components, or groups for element penetrations and intersections using the Penetration tool.
Check the connectivity between two or more components.
Use the Mass tool to calculate the mass, center of gravity (COG), and moments of inertia (MOI) of the model.
Explore the tools used to fix elements.
The Developer ribbon contains tools for automation and customization.
