Use the Matrix Browser to explore the HyperMesh and HyperView data entities and
export the entities to external files for further analysis.
From the Post ribbon, click the Matrix tool.Figure 1.
The Matrix Browser is organized into two main sections. The top
half of the browser provides a table view similar to an
Excel spreadsheet. The bottom half of the browser shows and
allows you to browse the HyperMesh/HyperView (data source) and its data entity (object) names
and their data names (attributes). The HyperMesh
database entities are shown in green and the HyperView
database entities are shown in yellow. When you select a column in the table it
becomes an active column and is highlighted in blue. All of the following searches
are conducted on the active column.Figure 2.
Matrix Browser Functionalities
Below is a highlight of the functionalities supported by the Matrix Browser.
Query and modify HyperMesh and HyperView data entities without writing cumbersome
Tcl coding.
Export HyperMesh and HyperView data to an Excel file for further
post-processing and report generation.
Establish a link between HyperMesh and HyperView in order to access model data, such as
material, property, beam section, and results data in a single environment.
The browser supports the selection of multiple load cases from the HyperView results database.
Create new procedures (macros) to enable automation with minimum Tcl coding and also capture the automation process
as Tcl scripts. These macros can be used
external to the Matrix Browser, like the tools in the
Altair script exchange.
Note: The Matrix Browser does not allow for the creation of new
HyperMesh entities. The tool queries and modifies
existing entity data. The browser also does not allow
extensive geometry (lines, surface, solids) data query. It is intended for FE data
and results that are already in the HyperMesh/HyperView databases.
Prepare to Use the Matrix Browser
Open an existing HyperMesh model or import solver
data.
Use the split screen and invoke HyperView.
Load the results file for the solved data into HyperMesh.
tool.
Figure 3. Figure 4. . Model opened in HyperMesh and HyperView.
Note:HyperView is only needed if the results are
accessed from the Matrix Browser.
Access HyperMesh Data Using the Matrix Browser
In the DataSource column, select HMdata.
In the Entities column, select a HyperMesh
entity.
Click Query.
In the panel area, use the entity selector to select
HyperMesh entities to add to the matrix.
A new green colored column is added to the matrix.
In the matrix, click the elements header to access
entity data.
The elements column turns blue when clicked, indicating the entities are
active for the search operation. The Datanames column is populated with entity
attributes from the HyperMesh database for the
element IDs shown in the elements column.Figure 5.
Select the material, property, or any other attribute(s) and click
Query.
One of more columns will be added. If you selected material, the
material IDs will be shown.
Component attributes you can select include:
Masses.
Center of gravity (CoG) coordinate, X, Y, or Z.
Moments of inertia components expressed from the origin (IXX, IYY,
IZZ, and so on).
Moments of inertia components expressed from the component CoG
(IXXcog, IYYcog, IZZcog, and so on.
Figure 6.
The next step is to get E, Nu from the material. Activate the
material column, and then select
E and Nu from the data
names.
Figure 7.
Click Query.
Repeat this process for property and get the element thickness.
Derived data
is not stored in HyperMesh data. It is calculated by a
procedure predefined by the Matrix Browser to calculate useful data
from HyperMesh data. You can create these Tcl procedures and store them in the Matrix start up. They will
show up in the browser as derived_datanames. The pre-installed
derived_datanames are width, height, radius and adjacent.
Access HyperView Results From the HyperMesh Database
Access HyperView Results From the HyperMesh Database with Multiple Subcases
Split the graphics area into two windows. In the first screen, use HyperMesh to load the model files. In the second screen,
use HyperView to load results files.
Figure 8.
The Matrix Browser opens.
In the Entities column, select the required element directly or select
components, material, property, or sets.
In the DataSource column, select HVdata.
In the Entities column, select Results.
In the Subcase Options column, select
multiple_subcases.
Figure 9.
Select the results type(s) available in the solver results.
Figure 10.
Select layer information (if available) and the results system in which the
results are to be interpreted.
User-defined system results are available as long as a system is available in
HyperView.
By default, the matrix only displays the results for each subcase in separate
column. Retrieve additional information by right-clicking and selecting
Show all columns from the context menu.
Access HyperView Results From the HyperMesh Database with the Current Subcase
Current_subcase selection is the same as multiple_subcase, except that it provides
the ability to create multiple worksheets when you run the macros.
Figure 11.
current_subcase.
Figure 12.
Select the results type.
In the HVSubcases dialog, select layer and system
information.
Results for the current subcase display in the column.Figure 13.
From the Macro pull-down, click Save.
Figure 14.
From the Macro pull-down, click Run.
After the macro is finished running, you will be asked to select the load case.
If you select multiple load cases, separate worksheets will be created for each
load case as in the case of current load case.
Figure 15.
Select the worksheet corresponding to the simulation.
Access HyperView Results From the HyperMesh Database with the Current Contour Results
In HyperView, select the required results and
contour data.
Figure 16. Figure 17.
Figure 18.
current_contour.
Figure 19.
The current contour selection does not prompt you for load case, layer, or
system information. The displayed results are queried in HyperView and sent to the matrix.
Query Max/Min Results for Components/Sets/Materials/Property
When you query max/min results for component/sets/material /property, HyperMesh will search the max/min values for the elements in that
component and provide single values and the element ID/load case ID where that values
occurs.
n the Entities column, select components, sets, materials, or property.
Figure 20.
Select results and the required data type.
In the HVSubcases dialog, select layer, corner data type,
system, and averaging methods.
Figure 21.
The max/min results for that component display. In a separate column,
additional data lines display the loads case and node/element information for
the particular data.Figure 22.
Create Notes in HyperView
In the Matrix Browser, you can create and delete
annotations (HV-notes) for selected column results using the context menu option Notes to HV.
Figure 23. Figure 24.
Create and Retrieve User Data in the Matrix Browser
It is often useful to add additional data that is not in the HyperMesh or HyperView databases,
which is known as user data.
Click user_data in the Data Source column.
Click Create in the user variables GUI column.
Click double in the variable types column.
Click Query.
In the dialog, provide the column label name, select Multiple
values, and activate the Create a column on
OK checkbox.
Figure 25.
Click OK.
The user data is added to the Matrix Browser.
In the matrix, right-click on the user data you created and select
Create Metadata from the context menu.
In the dialog, select entities to create metadata for.
Figure 26.
Retrieve this data using entity based metadata.
Figure 27.
Work with Microsoft Excel
Once the HyperMesh, HyperView, and user data is gathered in the Matrix Browser, the data can be exported to Excel by clicking
Excel in the top right-hand corner of the browser.
You can hide some of the columns that are not needed for export by selecting
Hide Columns from the context menu.
Figure 28.
You can also add more columns. To import the new column(s) from Excel into the
Matrix Browser, click
Matrix.
Display Data in HyperMesh or HyperView
Display data in HyperMesh.
Click Correlations > Contour.
A dialog opens.
Select elements for the Entity Column label and
Net_area for the Column on Y field.
Click OK.
The contour appears in HyperMesh.
Display data in HyperView.
Click Export > HyperView.
Select a column to export.
The exported data will appear in HyperView. You can post-process this data in the same manner as other HyperView data types.Figure 29. Figure 30. . Contouring in both HyperMesh and
HyperView.
Add Tcl Calculation Procedure
HyperMesh has a built in scripting language based on
Tcl programming language. Tcl is used to access HyperMesh and
HyperView functionalities\methods as well as internal
data. The following example calculates element strain (yy) from element 2D-Force-YY for
a shell element.
Click Procedure in the variable type column.
A dialog opens.
Enter the column and function name.
Activate the Create a column on OK checkbox.
Add the following Tcl code, based on Matrix and
column names, then click OK.
proc Element_strain_calc { } {
set force_fyy[::MatrixBrowser::getColumn2D_Element_Force:YY]
set width [::MatrixBrowser::getColumn Width]
set young_mod [::MatrixBrowser::getColumn E]
set thickness [::MatrixBrowser::getColumn PSHELL_T]
set Strain_yy ""
set Strain_yy [expr $force_fyy/$width/$thickness/$young_mod]
return $Strain_yy
Figure 31. . Element_strains are calculated and displayed.
Store and Reuse the Procedures Outside of the Matrix Browser
The process developed in the previous section can be stored as a macro (script) and
can be reused with another HyperMesh data model or other
Click Macro > Save.
Enter the Macro Name in the dialog and click OK.
This macro can also be added to the menu bar and
accessed and run without using the Matrix Browser. The
scripts are stored and can be reused like other scripts without the Matrix
tool.Figure 32.
Context Menu
The Matrix Browser's context menu
contains additional browser options.
Option
Import
Import Matrix or CSV.
Export
Export HyperView or CSV.
Correlation
Select Contour, Shape, Vector, or Plot.
Refresh
Refresh the Matrix Browser or HyperMesh session.
Delete
Delete selected rows, columns, or the whole table.
Macro
Save or run the macro.
Show all Columns
Show Columns
Hide Columns
Hide some of the columns that are not needed for export.
Entity Highlight
Select Show all, Show, Hide, Isolate, or Isolate Only.
Clear all
Clear the table.
Notes to HV
Create or delete notes.
Create Metadata
Create and save metadata for user data selected in the
matrix.
