/ALE/GRID/DONEA
Block Format Keyword Velocity of a given grid node depends on velocity and displacements of neighboring grid nodes.
| /ALE/GRID/DONEA | |||||||||
| Fscalex | Fscaley | Fscalez | |||||||
| Vmin | |||||||||
Definition
| DONEA
coefficient. Default = 0.0 (Real) |
| Grid velocity limitation
factor. Default = 100 (Real) |
| Fscalex | X grid velocity scale
factor. Default = 1.0 (Real) |
| Fscaley | Y grid velocity scale
| Fscalez | Z grid velocity scale
| Vmin | Elements with a volume
less than Vmin will
be deleted. Default = -1030 (Real) |
- This option is available for 2D and 3D analysis.
- Further explanation about this formulation can be found in ALE Formulation in the Radioss Theory Manual.
