/CLOAD
Block Format Keyword Defines a concentrated force or moment applied to each node of a prescribed nodal group.
/CLOAD/cload_ID/unit_ID
cload_title
fct_IDT Dir skew_ID sens_ID grnd_ID Ascalex Fscaley
Definition
cload_ID Concentrated load block identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
cload_title Concentrated load block title.
fct_IDT Time function identifier.
(Integer)
Dir Direction of load: X, Y, and Z for forces; XX, YY, and ZZ for moments.
(Text)
skew_ID Skew identifier.
(Integer)
sens_ID Sensor identifier.
≠ 0
The concentrated load is applied after sensor activation (the time function is shifted in time).
(Integer)
grnd_ID Node group to which the concentrated loads are applied.
(Integer)
Ascalex Abscissa scale factor.
Default = 1.0 (Real)
[ s ]
Fscaley Ordinate scale factor.
[ N ]
  1. The direction of load must be right justified in the ten characters of field number 2.
  2. The grnd_ID input is obligatory. The concentrated loads will only be applied to the nodal group. The force is applied to each node individually, so:
    t o t a l _ f o r c e = F ( t ) ⋅ N n o d e
    with N n o d e being the number of nodes in the node group.
  3. The Ascalex and Fscaley are used to scale the abscissa and ordinate.
    The actual load function value is calculated as:
    F ( t ) = F s c a l e y ⋅ f T ⋅ ( t A s c a l e x )
    Where, f T is the function of fct_IDT.
    The force is applied individually to each node of the nodal group. The total force is equivalent to the force value multiplied by the number of nodes.
