/GRNOD/GRBEAM
Block Format Keyword Describes the node groups which are selected from beam groups.
Enter selected item numbers (any number may be input, 10 per Line)
| /GRNOD/GRBEAM/grnd_ID/unit_ID | |||||||||
| grnd_title | |||||||||
| item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
| grnd_ID | Node group
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| grnd_title | Node group
| item_ID1, item_ID2,..., item_IDn | List of beam group
identifiers (Integer) |
- Node groups are used to define secondary nodes of rigid walls, interfaces, rigid bodies or nodes to which a load is applied, like a concentrated load or a fixed velocity.
- If item_ID is a positive GRBEAM id number, all nodes associated with the referenced beam group are added to the node group.
- If item_ID is a negative GRBEAM id number, the nodes associated with the referenced beam group are deleted from the node group.
