Hertz Formulation
Block Format Keyword The formulation is similar to a penalty formulation; but with a physical penalty stiffness based on Hertz contact theory.
Contact Treatment | Types | Application | Description | |
Hertz Formulation | Slide / Void | /INTER/HERTZ/TYPE17 | Meshes with 16-node thick-shell or 20 bricks | Using Hertz contact theory to describe impact between external surface of two brick groups. |
