*MAT_032 (LAMINATED_GLASS)
LS-DYNA Input Interface KeywordThis keyword defines a layered glass with polymeric layers material models.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_032 or *MAT_LAMINATED_GLASS | |||||||
| mat_ID | E_g | Νu_g | SIG_g | ET_g | EPSP_g | E_p | |
| Νu_p | SIG_p | ET_p | |||||
Add up to 4 cards (32 integration points).
| F1 | F2 | F3 | F4 | F5 | F6 | F7 | F8 |
| etc | |||||||
| etc | |||||||
| etc | etc | F30 | F31 | F32 |
Definition
| mat_ID | Material identifier. (Integer) | |
| Initial density. (Real) | ||
| E_g | Glass Young’s modulus. (Real) | |
| Nu_g | Glass Poisson’s ratio. (Real) | |
| SIG_g | Glass yield stress. (Real) | |
| ET_g | Glass plastic hardening modulus. (Real) | |
| EPSP_g | Glass plastic strain failure. (Real) | |
| E_p | Polymer Young’s modulus. (Real) | |
| Νu_p | Polymer Poisson’s ratio. (Real) | |
| SIG_p | Polymer yield stress. (Real) | |
| ET_p | Polymer plastic hardening modulus. (Real) | |
| F1 to F32 | Integration point material.
 (Real) |
- This keyword maps to /MAT/LAW27 (PLAS_BRIT) and /PROP/TYPE11 (SH_SANDW).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
