/TRUSS
Block Format Keyword Describes one dimension truss elements, which could be used with property /PROP/TYPE2 (TRUSS). Truss could only carry axial load (like for bar).
| /TRUSS/part_ID | |||||||||
| truss_ID | node_ID1 | node_ID2 | |||||||
Definition
| part_ID | Part identifier of the
block. (Integer, maximum 10 digits) |
| truss_ID | Element
identifier. (Integer) |
| node_ID1 | Node identifier
1. (Integer) |
| node_ID2 | Node identifier
2. (Integer) |
- The identifier must be unique in each element family, but it is advised for each element type to have a unique element identifier in the global model.
- More than one truss block may be used to define a part.
- Any number of trusses may be defined in one block.
- If a truss element is used with /MAT/LAW2 (PLAS_JOHNS), the strain rate dependency is not available.
