Configure FairShare via File
- -w (weight)
- Specify the relative weight of the group (default given by variable $FSGROUP(weights), which is normally 100).
- -t (timeWindow)
- Specify the time window used in the computation of the actual shares
(default given by variable $FSGROUP(windows) which is normally 7200,
which is 2 hours).Note: A time window of duration zero can be used to disable FairShare for a subset of the FairShare tree.
- -u (List-Of-Users)
- Specify a list of users that have exclusive access to that FairShare group. This access is controlled by an Access Control List.
- -user
- Specify that the group is a USER level group
A FairShare configuration file that represents current FairShare state can be created in the web user interface. Click . The vovfsgroup genconfig command provides a way to generate a FairShare cofiguration file from the CLI.
Tcl Example
% vovfsgroup genconfig config.mysetup.tcl
% vovfsgroup genconfig -leaf config.mysetup_with_leaf_nodes.tcl
% vovfsgroup loadconfig config.normal.tcl
Where config.normal.tcl contains the FairShare configuration declared in Tcl as follows:
# Copyright (c) 1995-2023, Altair Engineering
# All Rights Reserved.
# $Id: //vov/branches/2023.1.2/src/etcDir/config/fairshare/config.normal.tcl#2 $
# This is an example of config for fairshare.
FSGROUP "class" {
FSGROUP "sim" -w 0 -t 0 {
# In this branch, fairshare is disabled
# because the timewindow is zero (-t 0)
FSGROUP jolly
FSGROUP cronos -w 100 -t 3h
FSGROUP "urgent" -window 10m {
FSGROUP h2p -w 300
FSGROUP jolly
FSGROUP cronos
FSGROUP projects -w 133 {
FSGROUP jolly {
FSGROUP normal -w 200 {}
FSGROUP random -w 80 {}
FSGROUP cronos {
FSGROUP normal
FSGROUP random
Serial Example
The vovfsgroup genconfig -serial command provides a way to generate a FairShare configuration file in the "serial" format.
% vovfsgroup genconfig -serial config.mysetup.txt
% vovfsgroup genconfig -leaf -serial config.mysetup_with_leaf_nodes.txt
% vovfsgroup loadconfig config.normal.txt
# FairShare configuration file created by vovfsgroup on Mon May 02 16:55:09 EDT 2022
# Output is in tab-separated key=value format
# ACL values are in AGENT/NAME/ACTIONS format, with multiple ACLs separated by a comma
group=/ weight=16777215 window=-1s flatten=0
group=/time weight=100 window=1h00m flatten=0
group=/time/users weight=100 window=1h00m flatten=0 acl=OWNER//ATTACH DETACH EDIT VIEW STOP FORGET DELEGATE EXISTS CREATE,ADMIN//ATTACH DETACH EDIT VIEW FORGET CREATE,EVERYBODY//ATTACH DETACH VIEW
group=/system weight=100 window=0s flatten=0
group=/system/taskers weight=100 window=0s flatten=0
group=/system/taskers/closures weight=100 window=0s flatten=0
group=/system/taskers/messages weight=100 window=0s flatten=0
group=/system/vovdbd weight=100 window=0s flatten=0
