Multiple Tokens in FairShare
In FairShare, the number of license tokens
for each job is counted. Sometimes there are jobs that use four tokens of a license
and other jobs that use only one token of a license, each to access different
specific tool functionalities. For the best of use of resources and scheduling, it
may be undesirable to account for both types of jobs in the same way. To specify how
selected jobs contribute to FairShare, use
the field FSTOKENS
in the nc run ... submission
string.
The FSTOKENS
field can be set on each job of which the status is
neither Failed nor Done. The default value is 1. Typical values are small integers,
such as 2, 3, 4 or 8. The maximum value is 50000. The minimum value is 0, which
indicates that the job does not contribute to the FairShare value.
FSTOKENS
can be applied for jobs in which the status is not Failed
or Done.
FSTOKENS
in Accelerator use the option
-fstokens in nc run. An example using a
"MMSIM" license follows:
% nc run -fstokens 4 -r License:MMSIM#4 -- my_job_script_that_uses_4_tokens
-fstokens
. See Jobclasses for details.
