Disable FairShare
FairShare can be disabled on an individual node in the FairShare tree by setting the time window size to zero. When FairShare is disabled, jobs that belong to the disabled branches of the FairShare tree are scheduled using a round-robin scheduler that considers the oldest buckets first.
/class
, use the following command:
% vovfsgroup modrec /class window 0
This can be done at any time and has immediate effect, which is that all jobs in any
subgroup of /class
will be considered for scheduling based on the
time a job has been waiting in the queue.
Re-enable FairShare
% vovfsgroup modrec /class window 2h
% nc cmd vovproject sanity
