Install the ALM License Server Software
The ALM license server software and configuration files are included with the
Accelerator products, and are referred to as the "ALM bundle". The location is
$VOVDIR/alm. The files from that location should be copied
to a directory local to the server where the Altair License Manager will run. In
this example, the location /opt/alm_admin is used. The
installation and running of the license server should be done by a "role" account on
the Linux machine. Here, that role account is called almmgr
. The
steps are as follows:
