Update Licenses
When new floating licenses need to be served, or when replacement licenses are to be introduced, edit or replace the ALUS*.dat file in /opt/alm_admin with a file containing all the new licenses from the new ALUS*.dat files received from Altair. Then, stop and start the lmx-serv process by the procedure described in the previous section.
If an Accelerator product vovserver is running when these changes are made, the expired or removed license checkouts will be cancelled, and the vovserver will check out new licenses at the next heartbeat with no interruption of service.
