Install the Software
You may need to know the path to the current release in order to perform the operations described here. The path that is needed is the one that ends with the release number.
In the examples here, the current installation path will be shown as the /opt/rtda/2019.01 directory. When you see this in examples, you should understand that it is referring to the path to your current release.
In the previous step, you downloaded all the needed software patch files and placed them into the special patches directory within the current release.
For each software patch file, you need to run the install-patch script, passing it the name of the patch file to install.
You must be in the current release when you run the install-patch script from its location within the scripts directory. You must give it the relative name of the patch file in the patches directory. The processing depends on this arrangement for it to work correctly.
