Set Up Environment Variables
In order to run the software for validation, you need to set up your command line environment properly.
This includes changing your PATH environment variable so you can run the installed executables, and adding two environment variables that are used by the Altair Accelerator programs.
Platform Type | Shell | Command to Source File |
UNIX | csh tcsh | source /opt/rtda/2020.1/common/etc/vovrc.csh |
bash sh ksh zsh | . /opt/rtda/2020.1/common/etc/vovrc.sh | |
Windows | DOS | c:\rtda\2020.1\win64\bat\vovinit.bat |
The environment variable VOVDIR always points to the platform specific directory, so that, for example, the executables can be found in $VOVDIR/bin, the documentation can be found in $VOVDIR/doc, and the local information can be found in $VOVDIR/local.
