Plan to Install a Patch
This section contains a description of what to investigate as you consider installing software patches onto your current release. At the end of this activity, you will have a worklist of software patch files to install.
Check Available Patches
You can check the Altair website download page for the version of your current release to see if there are any published software patches.
Build a Worklist of Software Patches to Install
First, verify your current software patch level to ensure that you haven't already installed the latest patch. Complete the steps below:
You are now done building the worklist. This is the list of patch files that you you need to download and install.
