Block a Project from Returning to Shell
The option -block is used to prevent the project startup from returning to the shell. This is useful when the project is being started as a batch job in a scheduler environment. The -block option can be used when starting or creating a vovproject.
Examples:
% vovproject start -block
% vovproject create -block
