Change the Server Host
- The setup.tcl file in the server working directory
- The registry entry (normally located in $VOVDIR/local/registry/user/)
- For Accelerator only, the queue-specific configuration
file in the NC_CONFIG_DIR directory (usually
$VOVDIR/local/vncConfig
