API and Customization
New Features
- First release of HyperMesh Python API:- HyperMesh Python API allows you to automate your workflows via Python scripts.
- Supports creation of custom GUI via the hwx.gui module.
- Compatible with Extensions.
- Known Limitations:- All HyperMesh functions are not yet supported. Missing functionalities will be gradually added in the coming releases.
- Performance of creating collections in large models will be enhanced in the future.
- The model instance methods do not return a Python error when failing. Currently, the success/failure is captured via the returned status object. This behavior will be changed in the future, so a failed function returns a Python error.
- Nested entity data names are not yet accessible in Python.
- When executing a Python script via File > Load > Python Script, Python errors are suppressed.
- Known Issues:- Supplying entity name when creating a new entity via class constructor can result in an 'invalid value' error in case of a name conflict.
- Iterating over a collection and printing each objects may lead to application error.
- Invoking the interactive entity selection (CreateCollectionByInteractiveSelection) by supplying a model from a non-active window may lead to application error.
- The values of enums CONTAINMENT_FULL and CONTAINMENT_PARTIAL are mapped the wrong way.
- Incorrect size reported for collections of entities that use separate classes in Python to represent individual configurations.
- More information can be found in the Python API Reference Guide section of the API, Reference Guides.
- New Developer ribbon:- New ribbon has been added to host the tools planned for future releases related to automation and customization.
- The ribbon is hidden by default and can be activated via View > Ribbons.
- Task Manager:- New platform for process automation via Python API and XML defined GUI.
- Allows you to package custom Python scripts into tasks and organize them into a process that can be easily followed.
- Supports the HyperMesh client. Other clients will be supported in the future.
- More information on API changes can be found in the latest API Programmer's Guide section of the HyperMesh Reference Guide.
