Model Build
New Features
- ID Manager
- The ID Manager can now be opened by selecting the ID Manager tool from the Assembly ribbon.
- Parts
- Part name can now be customized on import using Part Name under PDM Attributes in the Geometry Import Options dialog.
- Controls
- For Part Controls, there are new options in Midmesh to set property creation to user defined thickness intervals rather than always using the automatic method.
Enhancements
- ID Manager
- Renumber has been moved to the top of the right-click context menu for ease of access.
- Parts
- Character support has been extended with non-alphabetic characters now allowed in Part's unique ID and representation name.
Resolved Issues
- Part entity ownership logic has been corrected. It was previously possible to have entities owned by a part by creating the entity when a part was current. This included any entity which was seemingly unrelated to that particular part. Following this, you would have no way of knowing or interrogating that the part had this content except when the part was deleted or unload and those entities were also deleted without warning. Parts now block these entities from accidentally being created in current part.
- Midmesh control minimum element size now defaults to 4x smaller than target element size rather than the previous 10x smaller. This should give better out of the box results and match the interactive Midmesh context results.
- The Similarity (%), Tolerance, and Value  options are now
                        correctly greyed out depending on which Match method is selected. options are now
