Design Explorer
New Features
- Generative Design
- Generative Design is a brand new workflow in the Design Explorer which
                            can be used to generate and consider many potential design concepts for
                            a given problem.Figure 1.
Enhancements
- MELS type DOEs can now be extended, allowing you to add additional runs to existing DOEs.
- Failed runs ignore in generation of response surface fit. Previously, any failed runs were included which, in some cases, could affect the fit quality.
Resolved Issues
- You are now able to select load cases when creating Measure responses.
- Additional Radioss groups, including Type 25, are now supported in Force response creation.
- You are now able to evaluate mass and volume responses for single OptiStruct PBARL or PBEAML properties.
