Post
New Features
- Animation
- Animation modes (linear, modal, transient) are now enabled.
- RSS Derived Load Case
- Root Square Sum (RSS) load case is available through the Derived Load Case workflow (together with Linear Superposition and Envelope).
- Extreme Principal Invariant
- Extreme Principal value as invariant has now been exposed. Value = Extreme(P1,P2,P3).
- Update Plot Controls Directly in the Legend
- You can now change plot control settings like Datacomponents, layers,
                            and so on directly in the Legend by hovering over the exposed lines and
                            selecting the relevant item.Figure 1.
Enhancements
- Principal Invariants in Tensor Plot
- Tensor Plot now has the possibility to display invariants in the modeling window.
- Free Body Groups and Trace Plot
- Trace Plot workflow has been migrated to the plot control paradigm.
Resolved Issues
- Nodes can now properly be selected in ISO display from Contour Plot.
- Contour plot for PSOLID with MCID has been corrected.
- Refactor messaging when results are not available.
- Resolved issue with reversed subcase order.
