Create Measure Responses
Use the Measure tool to create responses for supported measurements.
Restriction: Measure responses are not available for Generative Design
explorations.
From the Design Explorer ribbon, click the Measure
tool.
- Use the drop-down menu on the left side of the guide bar to select the measurement type.
Select one or more nodes.
The guide bar displays the required number of nodes per the selected measurement type.
- Optional:
In the microdialog, select
Objective or Constraint to
simultaneously create one.
Note: You can continue to define the constraint in the microdialog.
Click
on the guide bar to create the response.
