Create Stress and Strain Responses
Use the Stress/Strain tool to create stress and strain responses for selected elements or properties.
From the Design Explorer ribbon, click the Stress/Strain
tool.
- Use the drop-down menu on the left side of the guide bar to select the response type.
- Click the guide bar selector and choose whether to create the response using Elements or Properties.
- Optional: Check the Create one response for each selected entity option.
Select entities.
If the option above is unchecked, selecting the first entity will create a response. If the above option is checked, a response will be created for each selected entity.
- Optional: Make any desired modifications to the created response in the microdialog.
- Optional:
In the microdialog, select
Objective or Constraint to
simultaneously create one.
Note: You can continue to define the constraint in the microdialog.
