The Simplified Durability Tire model is a combination of the FIALA tire model and the 3D
enveloping contact method. The 3D contact method captures the road surface using a series of
parallel cams. The following characteristics of the road surface are captured:
Effective road height variation
Effective slope variation
Camber change
Based on the above variations, the forces are calculated using the FIALA algorithm. The 3D
contact method allows you to predict the enveloping behavior of tire when rolling over an
uneven surface.Figure 1.
Contact Patch Parameter Extraction from Testing
The following parameters are required to use the 3D enveloping contact with FIALA
tire:
PA1
Coefficient of square root term in contact length equation
PA2
Coefficient of linear term in contact length equation
PAE
Half of ellipsoid length
PBE
Half of ellipsoid height
PCE
Order of ellipsoid
PLS
Scaling of distance between front and rear ellipsoid
ROAD_INCREMENT
Mesh Size for ellipsoid
N_WIDTH
Number of cams along contact width
N_LENGTH
Number of cams along contact length
PA1, PA2 show the variation of the contact patch length. The size of the contact patch
increases with an increasing vertical load. The dimensions of the contact patch can be
obtained by pressing a tire on carbon paper or by using ink.Figure 2. Tire contact patch dimension 205/65 R16 at 4.7 KN and 2.5 bar
Contact Length Equation:
Contact Width Equation:
Details
Half of the contact patch length
Half of the contact patch width
Unloaded tire radius
Tire deflection
Width of the tire
Radial stiffness of tire
Using the curve of contact patch dimensions versus vertical load or vertical deflection you
can obtain PA1, PA2.
Important: The test matrix should have at least three
different vertical loads and constant pressure, 0 camber.
Ellipse dimension: When a tire starts rolling over an obstacle, the shape of the tire
circumference forms an elliptical contour. This is the basis of the elliptical cam contact
model. A set of images of a tire rolling over an obstacle can be post-processed to extract
the ellipse dimensions that are used in simplified durability tire. The image below presents
the idea of extracting ellipse dimensions from test images:Figure 3.
The equation for the shape of cam can be written as:
PCE is the order of these ellipsoids and can be obtained using curve fitting.
For PLS a standard value of 0.8 is used.Figure 4. Obstacle enveloping using elliptical cams
Tire parameter extraction from testing
For calculating the vertical load, the following parameters are needed:
Radial stiffness
Radial damping
These parameters can be obtained by simply pressing the tire and measuring the tire
deflection. The damping can be obtained by measuring the response of tire to an impulse
excitation.
For longitudinal force, the following parameters are needed:
Longitudinal slip stiffness
Relaxation length in longitudinal direction
Coefficient of friction between tire and road
For lateral force, the following parameters are needed:
