Defining an Output Using Two Points
Through this method, a displacement , velocity, or acceleration between two bodies can be measured relative to each other.
- Select Two Points from the Ouput Method drop-down menu.
- Click the Body 1 collector and pick the first body for the output request from the modeling window, or double-click the collector to display the Model Tree (from which the desired body can be selected).
- Similarly, pick the body for the Body 2 collector.
- Click the Point collector under Pt on Body 1 and pick the point for the location on Body 1.
- Select the point for the location on Body 2.
                Pick a reference marker for the output.
                The default marker is the global frame.
                Select I Marker, J Marker, or
                        Both from the drop-down menu next to the Ref Marker
                    collector.
                Selecting I Marker results in defining the output for Body 1 relative to Body 2 only. Selecting J Marker results in defining the output for Body 2 relative to Body 1 only. Selecting Both defines both of these outputs.Note: The points and bodies on which the output is requested cannot be pair entities.
