Using User-Defined Properties for an Output
Define the output using the User-Defined tab which will allow you to specify the properties of the output using user subroutines.
- From the Result Type drop-down menu, select User Defined.
                Define the user subroutine.
- Optional:
                Select the Define custom names and units check box in
                    order to provide custom names and units output channels returned by the
                    subroutine.
                - Additional tab Names/Units appears that contains Cnames and Cunits columns to enter the custom names and units.
- The custom names along with the units will appear as component names for the channels while plotting the results in HyperGraph.
