Import/Export Mesh Controls
Mesh controls can be saved and reused across different models by exporting them to a template file (*.xml) and then importing them into a new HyperMesh session from the Mesh Controls Browser.
All defined mesh controls are exported to a single .xml file, which can be utilized as a template. The mesh control parameters are saved to the file, while any entity selection is not.
From the Mesh Controls Browser, right-click on the Mesh
Controls folder and select Import or
Export from the context menu.
