*MAT_001 (ELASTIC)
LS-DYNA Input Interface KeywordDefines an isotropic, linear elastic material using Hooke’s law.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_001 or *MAT_ELASTIC | |||||||
| mat_ID | E | ||||||
Definition
| mat_ID | Material identifier. (Integer) |
| Initial density. (Real) |
| E | Young’s modulus. (Real) |
| Poisson’s ratio. Default = 0 (Real) |
- This keyword maps to /MAT/LAW1 (ELAST).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
