*MAT_077_O (OGDEN_RUBBER)
LS-DYNA Input Interface KeywordDefines an isotropic, hyperelastic, viscous, and incompressible material specified using the Ogden material models.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_077_O or *MAT_OGDEN_RUBBER | |||||||
| mat_ID | ν | N_pair | |||||
| μ1 | μ2 | μ3 | μ4 | μ5 | |||
| α1 | α2 | α3 | α4 | α5 |
| SGL | SW | ST | Fct_ID | DATA |
| Gi | i |
Definition
| mat_ID | Material identifier. (Integer) |
| Initial density. (Real) |
| v | Poisson’s ratio. Default = 0.495 (Real) |
| N_pair | The number of material parameter (μi and
αi) pairs calculated in the
representation of the strain energy density function (W). The
material parameters are calculated from the given stress-strain
curve (fct_ID). (N_pair ≤ 5) Default = 2 (Integer) |
| μ1 - μ5 | Parameter of the shear hyperelastic
modulus. (Real) |
| α1 - α5 | Exponent of the shear hyperelastic
modulus. (Real) |
| SGL | Specimen gauge length. | |
| SW | Specimen width length. | |
| ST | Specimen thickness. | |
| Fct_ID | Function identifier for the force versus change in gauge
length. Compression is defined in the 3rd quadrant (negative)
and Tensile is defined in the 1st quadrant
(positive). (Integer) |
| DATA | Experimental data type.
(Integer) |
| Gi | Shear modulus for relaxation. | |
| i | Decay constant for relaxation. |
- This keyword maps to /MAT/LAW42 (OGDEN) (if N_pair = 0) or /MAT/LAW69 (N_pair > 0).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
