*MAT_138 (COHESIVE_MIXED_MODE)
LS-DYNA Input Interface KeywordThis model expresses a constitutive relation of ductile adhesive materials in 2 modes for normal and tangential directions.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_138 or *MAT_COHESIVE_MIXED_MODE | |||||||
| mat_ID | ROFLG | Idel | EN | ET | GIC | GIIC | |
| XMU | TN | TT | UDN | UTD | Gamma | ||
Definition
| mat_ID | Material
identifier. (Integer) |
| Initial
density. (Real) |
| ROFLG | Mass calculation flag.
(Integer) |
| Idel | Failure flag indicating the number
of integration points to delete the element (between 1 and
4). Default = 1 (Integer) |
| EN | Stiffness normal to the plane of
the cohesive element. (Real) |
| ET | Stiffness into the plane of the
| GIC | Energy release rate for mode
I. (Real) |
| GIIC | Energy release rate for mode
II. (Real) |
| XMU | Exponent of the mixed mode
criteria. (Real) |
| TN | Peak traction in normal direction.
(Real) |
| TT | Peak traction in tangential direction.
(Real) |
| UDN | Ultimate displacement in the normal
direction. Used only if TN=0, then (Real) |
| UTD | Ultimate displacement in the
tangential direction. Used only if TT=0, then (Real) |
| Gamma | Benzeggagh-Kenane exponent for the
mixed mode. (Real) |
- This keyword maps to /MAT/LAW117.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
