*MAT_002 (ORTHOTROPIC_ELASTIC)
LS-DYNA Input Interface KeywordThis model expresses a simple orthotropic elastic material.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_002 or *MAT_ORTHOTROPIC_ELASTIC | |||||||
| mat_ID | E11 | E22 | E33 | υ12 | |||
| G12 | G23 | G31 | AOPT | ||||
| A1 | A2 | A3 | |||||
| D1 | D2 | D3 | |||||
Definition
| mat_ID | Material identifier. (Integer) |
| Initial density . (Real) |
| E11 | Young's modulus in direction 1. (Real) |
| E22 | Young's modulus in direction 2. (Real) |
| E33 | Young's modulus in direction 3. (Real) |
| υ12 | Poisson's ratio. (Real) |
| G12 | Shear modulus in direction 12. (Real) |
| G23 | Shear modulus in direction 23. (Real) |
| G31 | Shear modulus in direction 31. (Real) |
| AOPT | Orthotropy axis option.
(Integer) |
| A1, A2, A3 | First orthotropy direction vector for AOPT
= 2. (Real) |
| D1, D2, D3 | With A1, A2,
A3 determines 12 planes of orthotropy for
AOPT =
2. (Real) |
- This keyword maps to /MAT/LAW25 (COMPSH) and orthotropic element property (/PROP/TYPE9 (SH_ORTH), /PROP/TYPE6 (SOL_ORTH).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
