Creating a Data Source
Panopticon Streams supports creation of data sources that can be used as inputs or outputs in the application model.
- On the Data Sources tab:
- Click
on the toolbar, or - Right-click on a folder or subfolder and select New Data Source.
The New Data Source dialog displays.
- Click
- Enter the Name of the data source and click
The Data Source tab displays with the following sections:
Section/Pane Description Data Source Name
Name of the data source. Click the
button to go back to the Data Sources listing page.Connector drop-down list
Includes the input data sources and output connectors.
Save
Saves the changes made on the Data Sources tab.
NOTE: Inactive connectors are not displayed in the Connector drop-down.
- Enter the Name of the data source. This should be unique and should only contain letters (a to Z), numbers (0 to 9), and underscores.
- Click
or press Enter to apply the name. - Select any of the following:
- Output connectors
- Input Data Sources
- ActiveMQ
- Altair AI Hub
- Azure
- AMPS
- Cassandra
- DolphinDB
- DolphinDB- Streaming
- Google Analytics
- Google Cloud
- Google Cloud Pub/Sub
- InfluxDB 1.x
- JDBC Legacy
- JDBC
- JSON
- Apache Kafka
- Kx kdb+
- Kx kdb+ Tick
- ksqlDB
- ksqlDB- Streaming
- MongoDB
- MQTT
- MS Excel
- OneTick
- OneTick CEP
- Python
- RabbitMQ
- Rserve
- S3
- Solace
- Stream Simulator
- StreamBase 7.1
- StreamBase LiveView
- Text
- WebSocket
- Web Data
- XML
