ACU-T: 6102 Particle Separation in a Windshifter using AcuSolve - EDEM Bidirectional Coupling
This tutorial introduces you to the workflow for setting up and running a basic bidirectional coupling (two-way) simulation using AcuSolve and EDEM. Prior to starting this tutorial, you should have already run through the introductory tutorial, ACU-T: 1000 Basic Flow Set Up, and ACU-T: 6100 Particle Separation in a Windshifter using Altair EDEM, and have a basic understanding of HyperMesh CFD, AcuSolve, and EDEM. To run this simulation, you will need access to a licensed version of HyperMesh CFD, AcuSolve, and EDEM.
Problem Description
The model consists of a cylindrical pipe with a 45-degree bend. The radius of the pipe is 0.25 m and the particle inlet is located midway through the length of the pipe.
Accordingly, the tutorial consists of two parts:
- AcuSolve setup and geometry export
- EDEM setup and simulation
The AcuSolve model will be set up using HyperMesh CFD. Once the AcuSolve setup is complete, the EDEM deck with the geometry will be exported from HyperMesh CFD. This input deck will be opened in EDEM and will be used to complete the EDEM setup. Once the EDEM deck is set up, you will launch the coupled simulation.
Two different bulk materials used in the EDEM simulation and their properties are listed below:
Name | Density (kg/m3) | Particle radius (m) | Average weight of individual particle (kg) | Rate of generation (particles per sec) |
Heavy particle | 900 | 0.03 | 0.1 | 100 |
Light particle | 100 | 0.03 | 0.01 | 100 |
Part 1 - AcuSolve Simulation
Figure 4.
The Open File dialog opens. - Browse to the directory where you saved the model file. Select the HyperMesh file ACU-T6102_windshifter.hm and click Open.
- Click .
Save the database as windshifter_bidirectional in
the same directory as the other input files.
Validate the Geometry
Set Up Flow
Figure 6.
The Setup dialog opens. - Under the Physics models setting, select the Multiphase flow radio button.
- Change the Multifluid type to Bidirectional EDEM Coupling.
Click the Eulerian material drop-down menu and select Material
Library from the list.
You can create new material models in the Material Library.
In the Material Library dialog, select EDEM 2 Way
Multiphase, switch to the My Material
tab, then click
to add a new material model.
- In the microdialog, click EDEM Bidirectional Material in the top-left corner and change the name to Air-Particle.
- Set the Carrier field to Air (if not set already).
Set the drag model and the drag coefficients as shown in the figure
below.
Figure 7.
- Close the material model microdialog and then close the Material Library dialog.
- In the Setup dialog, set the Eulerian Material to Air-Particle.
Set Time step size and Final time to 0.001 and
1, respectively. Select
Spalart-Allmaras for the Turbulence model. Verify
that Gravity is set to 0, 0, -9.81, as shown below.
Figure 8.
Click the Solver controls setting and set the Minimum
and Maximum stagger iterations to 2 and
4, respectively.
Figure 9.
- Close the dialog and save the model.
Assign Material Properties
Figure 10.
- Verify that Air-Particle has been assigned as the material.
On the guide bar, click
to exit the tool.
From the Flow ribbon, Profiled
tool group, click the Profiled Inlet tool.
Figure 11.
Click on the inlet face highlighted in the figure below. In the microdialog, enter a value of 20 m/s
for the Average velocity and set the Carrier fluid volume fraction to
1.0.
Figure 12.
to execute the command and exit the tool.
Click the Outlet tool.
Figure 13.
Select the face highlighted in the figure below and then click
on the guide bar.
Figure 14.
Click the No Slip tool.
Figure 15.
Select the face highlighted in the figure below.
Figure 16.
In the Boundaries legend, double-click Wall and rename
it to Particle_inlet.
You will use this surface as a reference geometry to create a particle factory in EDEM. Hence, you are placing this surface in a different geometry group.
Click
on the guide bar.
- Save the model.
Generate the Mesh
From the Mesh ribbon, click the
Volume tool.
Figure 17.
The Meshing Operations dialog opens. -
Change the Average element size to 0.3.
Figure 18.
Click Mesh.
The Run Status dialog opens. Once the run is complete, the status is updated and you can close the dialog.Tip: Right-click on the mesh job and select View log file to view a summary of the meshing process.
- Save the model.
Define Nodal Outputs
Once the meshing is complete, you are automatically taken to the Solution ribbon.
From the Solution ribbon, click the Field tool.
Figure 19.
The Field Output dialog opens. - Check the box for Write Initial Conditions.
Set the Time step interval to 10.
Figure 20.
Export the Solver Deck
- From the menu bar, go to .
- Name the file windshifter_bidirectional and make sure that AcuSolve (*.inp) is selected as the file type.
- Click Save.
Part 2 - EDEM Simulation
Start Altair EDEM from the Windows start menu by clicking .
Open the EDEM Input Deck
As mentioned earlier, when the AcuSolve simulation was launched, HyperMesh CFD created a set of EDEM files in the problem directory. You will open that EDEM input deck and setup the DEM simulation.
- In the Creator tab in EDEM, go to .
In the dialog, browse to the AcuSolve problem
directory and open the windshifter_bidirectional.dem file located in the EDEM
folder.
The geometry is loaded.
Click the Environment tab under the Creator Tree,
uncheck Auto Update from Geometry, and then check the box
again to fit the geometry within the boundary.
Figure 21.
Figure 22.
Define the Bulk Materials and Equipment Material
In this step, you will define the material models for the heavy and light bulk material and the equipment material.
- In the Creator Tree, right-click Bulk Material and select Add Bulk Material.
- Rename the material to Heavy.
In the Creator Tree, set the Solids Density property to
900 kg/m3.
You will use the default values for other properties for this tutorial.
Figure 23.
Click
below Interaction to define the interaction properties for collisions among the heavy particles. In the dialog, click OK.
- In the Creator Tree, right click Heavy and select .
- Rename the particle to Heavy particle.
- Under Heavy particle, click Properties.
In the Heavy particle Spheres panel, set the Physical Radius of both the
spheres to 0.03 m and press Enter.
Figure 24.
In the Creator Tree, click Calculate Properties.
Figure 25.
- Rename the material to Light.
100 kg/m3.
Figure 26.
Click
below Interaction to define the interaction properties for collisions among the heavy particles. In the dialog, select Heavy and then click OK.
Click
again to define the interaction properties for collisions among the light particles. In the dialog, select Light and then click OK.
- In the Creator Tree, right click on Light and select .
- Rename the particle to Light particle.
- Under Light particle, click Properties.
In the Light particle Spheres panel, set the Physical Radius of both the
Figure 27.
Figure 28.
- In the Creator tree, right-click Equipment Material and select Add Equipment Material. Rename it to Steel.
- Set the Density to 7800 kg/m3.
Click
Click
- Save the model.
Create the Particle Factory
- Expand Geometries under the Creator Tree tab. Next, right-click the Particle inlet surface group and select .
- Rename the new geometry section to Particle_factory.
- Right-click the Default Wall geometry section in the Creator Tree and select Merge Geometry(s).
- In the Merge Geometry dialog, select the Particle_inlet and then click OK.
Click the Default Wall geometry section, set the Type to
Physical, and the Material to
Steel (if not set already).
Figure 29.
- In the Creator Tree, click the Inlet section and change the Type to Virtual.
- Similarly, change the Type to Virtual for the Outlet and Particle_factory sections.
Under Particle_factory, click Transform. Set the
X-Position to 0.035 m
Figure 30.
Note: Set the Opacity value to 0.2 to see the transformed surface location inside the pipe geometry.This is done to make sure that the particles are generated inside the fluid domain.
Define the Particle Factory
Now that the bulk material, geometry sections, and equipment materials are defined, you need to create a particle factory to generate the particles. You will create one factory for each bulk material.
- In the Creator Tree, right-click Particle_factory and select Add Factory.
- Rename the new factory to Heavy factory.
Set the particle generation parameters as shown in the figure below.
Figure 31.
Click
besides Velocity, set the X-velocity to 1 m/s, and then click OK.
- Repeat steps 1-4 to create another factory named Light factory using the same parameters but with Light as the Material.
Define the Environment
In this step, you will define the extents of the domain for the EDEM simulation and the direction of gravitational acceleration.
- In the Creator Tree, click Environment.
Activate the checkbox for Auto Update from Geometry (if
not already selected).
When a moving particle touches the bounding faces of the domain (environment), it will be removed from the simulation.
- Activate Gravity and set the z-value to -9.81 m/s2.
- Save the EDEM deck.
Define the Simulation Settings
Click
in the top-left corner to go to the EDEM Simulator tab.
In the Simulator Settings tab, set the Time Integration scheme to
Euler and deactivate the Auto Time
Step checkbox.
Note: The Auto time step should never be used for AS-EDEM bidirectional coupled simulations.
Enter a value of 2e-5 for Fixed Time Step.
When setting the time step for the DEM model, make sure that the CFD time step is an integer multiple of DEM time step. In this case, the CFD time step is 1e-3, which is 50 times the DEM time step. This ensures that the physical time in both the solvers match at the end of each data exchange interval. Also, the recommended range for the CFD-to-DEM time step ratio is 50-200 for most cases.
- Set the Total Time to 1 s and the Target Save Interval to 0.01 s.
Set the Cell Size to 4 R min.
Generally, a value in the range of 3-6 Rmin is recommended as the optimum cell size. The cell size in EDEM does not have any impact on the accuracy of the simulation and affects only the run time.
Set the Selected Engine to CPU Solver and set the Number
of CPU Cores based on availability.
Figure 32.
- Once the simulation settings have been defined, save the model.
Submit the Coupled Simulation
Start the coupling server by clicking Coupling Server in
EDEM.
Figure 33.
Once the Coupling server is activated, the icon changes.Figure 34.
- Return to HyperMesh CFD.
Figure 35.
- Expand Default initial conditions, uncheck Pre-compute flow and set the velocity values to 0. Uncheck Pre-compute Turbulence.
Click Run to launch AcuSolve.
Figure 36.
If the coupling between AcuSolve and EDEM is successful, a message will be printed in the AcuSolve Log file before the first time step.Figure 37.
Analyze the Results
AcuSolve Post-Processing
- Once the solution is completed, navigate to the Post ribbon.
- From the menu bar, click .
Select the AcuSolve
.log file in your problem
directory to load the results for post-processing.
The solid and all the surfaces are loaded in the Post Browser.
Select the Left face on the view cube to align the model
to the x-z plane.
Figure 38.
In the Post Browser, turn off the display of the boundary
surfaces by clicking on the icon next to Flow Boundaries.
Figure 39.
Click the Slice Planes tool.
Figure 40.
- In the modeling window, click on the plane that is parallel to the screen (the x-z plane).
In the slice plane microdialog, click
to create the slice plane.
- In the display properties microdialog, set the display to velocity and activate the Legend toggle.
- Change the upper bound of the legend to 36.
Click
and set the Colormap name to Rainbow Uniform.
Figure 41.
Click
on the guide bar.
The velocity contour should look like the one shown below at the beginning of the simulation.Figure 42.
Plot the contours at 0.25s, 0.5s, 0.75s, and 1.0s by dragging the slider on the
bottom to the 26th, 51th, 76th, and
101st frames.
Figure 43.
Figure 44.
Figure 45.
Figure 46.
- Right-click Slice Plane 1 in the Post Browser and select Edit.
- In the microdialog, change the Display variable from velocity to volume fraction edem particle and set the upper bound of the legend to 0.186.
Click
on the guide bar.
Figure 47.
Plot the contours at 0.5s (step=51/101), 0.75s (step=76/101), and 1.0s (step =
101/101) to see the volume fraction edem particle distribution inside the fluid
domain.
Figure 48.
Figure 49.
Figure 50.
EDEM Post-Processing
Once the EDEM simulation is complete, click
in the top-left corner to go to the EDEM Analyst tab.
- In the Analyst Tree, expand Default Wall. and then click
Verify that the Display Mode is set to Filled and set
the Opacity to 0.2.
Figure 51.
- In the Analyst Tree, expand Particles and click Heavy particle.
Change the display color to Magenta.
Figure 52.
Click on Light particle and set the display color to
Green.
Figure 53.
On the menu bar, set the time to
0 by clicking:
Figure 54.
Set the View plane to + Y.
Figure 55.
In the Viewer window, set the Playback Speed to 0.1x
then click on the play icon to play the particle flow animation.
Figure 56.
You can also plot the results at different timesteps by clicking the drop-down
menu.
Figure 57.
For the current case, the results are plotted at 0.25s, 0.5s, 0.75s, and 0.98s to see the particle distribution inside the fluid domain at both inlet and outlet.Figure 58.
Observe that the lighter particles (green) get carried by the fluid and escape the domain through the outlet at the top and the heavier particles (magenta) stay inside the domain for a longer time while some of them fall through the bottom of the pipe.
On the menu bar, click the Create
Graph icon
In the Analyst Tree, change the plot type to Line by clicking
Click the X-axis tab and verify that the values are set
Figure 59.
Click the Y-axis tab. Create a plot of average residence
time of the heavy particle over the simulation time by setting the values as
Figure 60.
Click
to add another Y-axis and set the Type to Light particle.
Figure 61.
Leave all the other options unchanged and then click Create
Graph to create a plot of average residence time of both the
particles.
Figure 62.
The plot in green is for the heavier particles and it can be observed that the average residence time is higher for the heavier particles compared to the lighter particles (blue).
Summary
In this tutorial, you learned how to setup and run a basic AcuSolve-EDEM bidirectional (two-way) coupling problem. In the first part, you set up the AcuSolve model in HyperMesh CFD and exported the geometry. Next, you imported the EDEM input files created by HyperMesh CFD, set up the EDEM model, and ran the coupled simulation. Once the coupled simulation was completed, you have learned how to create animations and plots in both HyperMesh CFD Post and EDEM Analyst.
