2024
View new features for Altair HyperWorks 2024.
Use the Notes tool to label items, describe trends, and relate additional information.
Use the Tracing tool to trace system, component, and node entities during animation.
A new workflow emphasizing the multicore profile for standard crash post processing use cases.
The Developer ribbon contains tools for automation and customization.
