2024
View new features for Altair HyperWorks 2024.
Realistic Rendering is a new graphics mode that is based off of the physically based rendering model approach that allows for the flow of light to be rendered more accurately as it would be in the real world.
A new workflow emphasizing the multicore profile for standard crash post processing use cases.
The Developer ribbon contains tools for automation and customization.
