2024
The vehicle library models most four-wheeled vehicles in production today. Models can be modified interactively in MotionView to support topologies that are not supported in the vehicle library. The vehicle library is open-source, ASCII-based, and can be modified by you. The methods in the vehicle library can also be used and adapted to model non-automotive land vehicles, such as tractors and trucks.
View new features for Altair HyperWorks 2024.
The Developer ribbon contains tools for automation and customization.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
Add an FMU to the model or export a model as an FMU.
A widely used process in the automotive industry is to split the suspension design and development into three distinct stages. The stages are typically performed by different teams working in different locations and at different times during the vehicle program. Ideally, the teams will share model data, modeling methods, and results widely. Since the teams are working on the same vehicle, the engineering lessons learned by one group will need to be shared with the other two teams.
All of the MotionView models can be used in either a Design of Experiments (DOE) or Optimization study using the HyperStudy client.
In a front MacPherson strut (1pc LCA) suspension the knuckle and wheel are located by a control arm and strut. The coil spring is part of the strut and acts between the strut tube and the vehicle body. The spring’s axis typically is not parallel to the strut, but is offset to minimize the bending moment in the strut.
In a front MacPherson strut (2pc LCA) suspension, the knuckle and wheel are located by a control arm and strut. The coil spring is part of the strut and acts between the strut tube and the vehicle body. The spring’s axis typically is not parallel to the strut, but is offset to minimize the bending moment in the strut.
The multi-link suspension derives its name from the fact that it is made up of three or more links. The MotionView multi-link suspension contains four links, and it is generally used on cars and off-road vehicles. This suspension offers flexibility to the designer, since each link’s location can be determined independently.
The Short-Long Arm (SLA) suspension is also known as a Double Wishbone suspension. The SLA name is derived from the length of the control arms. The lower arm is typically long to provide a good spring lever ratio. The upper arm is typically short to provide the proper camber curve. This suspension is widely used on cars, light trucks, and on independent suspension heavy trucks.
A Short-Long Arm (SLA) suspension configuration is also known as a Double Wishbone suspension. The SLA name is derived from the length of the control arms. The lower arm is typically long to provide a good spring lever ratio. The upper arm is typically short to provide the proper camber curve. This suspension is widely used on cars, light trucks, and on independent suspension heavy trucks. The two-piece lower control arm is the only difference between the two front SLA suspensions.
The rear suspension model is built using the same process as the front suspension. Eleven different rear suspensions are available using the Assembly Wizard.
Events create motions and forces in the model which make the system move. Most events add additional parts to the model to perform the simulation.
The Task Wizard dialog allows you to select the analysis tasks to be run.
The attachments specified during the assembly process (using the Assembly Wizard dialog) can be modified using the Attachment Wizard, located on the Assembly ribbon. The Attachment Wizard dialog guides you through the process of modifying the model attachments.
The Set Wizard Path dialog allows you to select directories in which several files are stored.
Reference material for the scripting interface which is a set of Tcl/Tk commands.
