2024
Controllers form the core of the driver. The Controller Library has various basic controllers its arsenal to calculate different driver outputs.
Closed-loop controllers use vehicle responses (for example, speed, position, yaw rate, etc.) as feedback to determine the vehicle inputs needed to match a desired vehicle response, such as following a demand lean profile (for two wheelers) or a path.
View new features for Altair HyperWorks 2024.
The Developer ribbon contains tools for automation and customization.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
Add an FMU to the model or export a model as an FMU.
This section describes how to add a full vehicle model with the Altair Driver and include the events. The events are simulation commands that enable the Altair Driver control to perform the vehicle maneuvers. A model with an event exports an Altair Driver File (.adf) and the MotionSolve (.xml) files to be simulated.
This section describes all of the full vehicle events currently supported with Altair Driver. It also describes all of the events and their parameters.
The Altair Driver is a set of MotionView models and libraries that allows MotionView users to control and script vehicle events.
Open-loop controllers define vehicle inputs directly without feedback (for example, steering wheel angle vs. time).
Driver can be loaded using the Model Wizard of MDLLIB when the Full Vehicle with Driver option is chosen. Driver has some special requirements to interface with the vehicle model. These requirements are resolved automatically if the vehicle model is built using the Full vehicle with advanced driver option in the Model Wizard in MDLLIB.
Driver uses the Altair Driver File (ADF) to access all the event parameters in the Solver.
Reference material for the scripting interface which is a set of Tcl/Tk commands.
