2024
View new features for Altair HyperWorks 2024.
In this tutorial, you will learn how to create a new library in the personal repository, create and manage workspaces in a managed library, and use the Organize browser to organize and explore categories and folders.
In this tutorial, you will learn to add an existing library to the personal repository, work with contents in a managed library, and become familiar with versioning and life cycle operations.
Collaboration Tools profiles are a collection of content types, parsers and customizations using Collaboration Tools APIs and Tcl/tk scripting.
The Developer ribbon contains tools for automation and customization.
