2024
Add horizontal and vertical datum lines to plots.
View new features for Altair HyperWorks 2024.
The Developer ribbon contains tools for automation and customization.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Edit existing bar charts individually and add new bar charts to the current plot.
Annotate plots using notes.
See Datums for more information.
