Use Values as a Data Source
- From the Bar Chart Define Curves dialog, select .
Enter a value in the Curve column of the Values table. You can enter a value
for each available bar chart category.
You can also plot category values using a Templex function. For example, {p1w1.category}.
- Click Apply.
