Edit a Curve with File as the Data Source
- From the Bar Chart Define Curves dialog, select a bar series from the list or pick a bar chart from the window.
- Select or enter the new data for the vector.
Click Apply.
The changes to the curve are reflected in the HyperGraph window.
