Add or Delete a Row to the Values Table
- From the Bar Chart Define Curves dialog, select .
From the table, click a row's number, right-click, and select Insert
Above or Insert Below from the context
sensitive menu.
A row is added to the Values table.
- Select a row from the table.
Right-click and select Delete from the context-sensitive
menu.
The row is deleted from the table.
