Double Lane Change
A Double lane change event drives the vehicle through a lane change and a return to lane maneuver, attempting to follow the centerline of the defined lane.
You can define the speed of the lane change, along with the lane dimensions. The Altair Driver model is used to maintain speed throughout the event. The event supports right and left lane changes.
The double lane change event is supported by the Cars & Small Trucks, Heavy Trucks, and Two-Wheeler vehicle libraries. Automated output reports are available to plot the results.
| Parameter Name | Description |
| Units | Describes the Length, Velocity, and Acceleration units.
| Lateral offset | Offset distance of the double lane change. |
| Length- Section 1 | Length of the initial straight section of road. |
| Length- Section 2 | Longitudinal length of the initial lane change section of road. |
| Length- Section 3 | Length of the center straight section of road. |
| Length- Section 4 | Length of the second lane change section of road. |
| Length- Section 5 | Length of the recovery section of road. |
| Velocity | The initial speed of the vehicle. |
| Turn direction | Direction the vehicle turns during the event (as seen by the driver). |
Controller Settings
- Non-leaning events (Cars/Trucks)
- LONGITUDINAL – TRACTION CONTROLLER SETTINGS
- Use additional control: Enables the additional feedback control for the traction
control. The gains for the controller can be edited by toggling this check
box.
Kp Proportional gain for the feedback PID controller Ki Integral gain for the feedback PID controller Kd Derivative gain for the feedback PID controller
box.
- Leaning events (Two-wheelers)
box.
box.
Signal Settings
Use the signal settings to set minimum, maximum, smooth frequency and initial values for Steering, Throttle, Brake, Gear, and Clutch signals output by the driver.
The smoothing frequency is used to control how fast the Driver changes signals. Only closed loop control signals from the Driver are smoothed. Open loop signals are not smoothed.
Road Settings
- Flat Road
- Uses a flat smooth road for the event with no required road file.When the Flat Road is selected, the Graphics Setting option is available with the following parameters:
- View path centerline: Enables the visualization of the event path.
- This check box is disabled for open loop events without a path.
- View grid graphics: Enables the visualization of the road grid graphics.
- When view grid graphics check box is toggled, road grid parameters can be edited in the Grid Settings tab.
Grid length Defines the length of the road. Enter a positive value in the model units. Grid Width Defines the width of the road. Enter a positive value in the model units. Grid X offset Gives a distance offset to the road graphics in the longitudinal direction. Enter a positive value in the model units. Grid Y offset Gives a distance offset to the road graphics in the lateral direction. Enter a positive value in the model units.
- Road File
- The road file option enables the selection of a road file to be used in the event. Using this option, all tires in the model consider the event specified road file instead of the file included in the tire entities.
- Tires
- Using Tire as road selection option, the road file specified in the tire entity is used in the events simulation.
Automated Output Report
| Report Name | Report Signals |
| Steering Input and Accelerations |
| Vehicle Velocities |
| Vehicle Slip Angles |
| Roll Angle |
| Steer/Suspension Travel |
| Steering, roll and torque |
| Vehicle Slip vs. Acceleration |
| Steering Wheel Angle vs. Vehicle Sideslip Angle | |
| Vehicle CG Displacement |
