Remove an Entity from a Model
- From the Model Browser, right-click on the entity that you would like to remove.
Select Delete from the context menu.
A dialog is displayed warning you that dependencies may exist and prompts you to cancel or continue.
Click OK to remove the entity.
Tip: Click Cancel to cancel the operation.
