Run a MotionSolve File
Run an existing solver command file previously generated by MotionView.
From the Analyze ribbon, Run tool
group, click the Solution drop-down menu and select
Run Solver Script.
The Run MotionSolve script dialog is displayed.
- Click the MotionSolve file browser button to select a command file from the directory.
- Select a registered solver script from the Solver script drop-down menu.
- Click Run to execute the solver.
