Change the Color of Entities
Change the display color of entities in the modeling window.
Select entities then do one of the
following:
- Right-click in the modeling window and select Color from the context menu.
- Click the color swatch in the
column of a browser.
- Click the color swatch in the Entity Editor.
A color palette displays.Figure 1.
- Optional: Change the color scheme using the drop-down menu.
- Choose a new color to represent the selected entities.
Tip: If multiple entities are selected, click
to automatically assign unique
colors to them.
Auto-color is not available from the Entity Editor.
Create and Assign Custom Colors
From the color palette, click
The Color Picker dialog is displayed.Figure 2.
- Define color properties using the custom color widget.
- Optional: Click Add to save the custom color.
