2024
Supported solvers in HyperView.
Overview of how the HyperView applications interface with the Nastran solver.
View new features for Altair HyperWorks 2024.
Load a different solver interface in the application.
Supported solvers in HyperMesh.
When you select a model or results file, HyperView automatically detects the file type and selects the proper reader to import the data.
Overview of how the HyperView applications interface with the Abaqus solver.
Overview of how the HyperView applications interface with the ADAMS solver.
Overview of how the HyperView applications interface with the ADVC solver.
Overview of how the HyperView applications interface with Animator DB.
Overview of how the HyperView applications interface with the ANSYS solver.
Overview of how the HyperView applications interface with the EDEM solver.
Overview of how the HyperView applications interface with the I-DEAS solver.
Overview of how the HyperView applications interface with the LS-DYNA solver.
Overview of how the HyperView applications interface with the LS-NIKE3D solver.
Overview of how the HyperView applications interface with the MADYMO solver.
Overview of how the HyperView applications interface with the MARC solver.
Overview of how the HyperView applications interface with Moldflow.
HyperView supports Nastran FEMZIP, OP2, XDB and H5 result file formats.
Animation files are loaded using the Load Model panel.
The options on the Contour, Tensor Plot, and Vector Plot panels in HyperView are based on the Nastran and OptiStruct solvers.
In HyperView you can transform stress results to any coordinate system following certain system projection rules. You also can calculate the stress average using various averaging schemes, and have control over which stresses should be averaged.
The Nastran XDB Results Reader can be customized by using the Reader Options dialog in the Load Model panel.
2D element forces and moments are supported as tensors and can be plotted using the Tensor panel in HyperView.
1D element forces and moments are supported as vectors and can be plotted using the Vector panel in HyperView.
Overview of how the HyperView applications interface with the OptiStruct solver.
Overview of the HyperViewnSOFT interface.
Overview of how the HyperView applications interface with the PAM-CRASH 2G solver.
Overview of how the HyperView applications interface with the Radioss solver.
Starting with 2024, HyperView will no longer directly support AcuSolve log files. HyperMesh-CFD will be the solution for supporting all CFD related workflows in the HyperMesh environment, including AcuSolve results.
Load post-processing files using the Load Model panel.
Supported solvers in HyperGraph.
Solvers and translators supported in MotionView.
The Developer ribbon contains tools for automation and customization.
For detailed information about complex results, refer to Complex Results.
