Check or Smooth Shapes
Use the Check/Smooth function to check the element quality of shape combinations and optionally smooth the shapes to improve the element quality when applied individually or as part of a combination of shapes.
The check and smooth functionalities are intended to make shape optimization more productive. Shape optimization solvers, like Radioss, will stop iterating if the element quality falls below certain limits. The check and smooth functions help to improve the element quality when shapes are applied simultaneously as well as calculate the maximum and minimum bounds at which the shapes can be applied to ensure successful completion of an optimization run.
From the Morph ribbon, click the Shapes tool.
The Edit Shapes dialog opens. - Select the shapes to check or smooth.
Right-click one of the selected shapes, and select
Check/Smooth from the context menu.
The Check/Smooth dialog opens.
Select the options in the Check/Smooth dialog.
Option Description smooth shapes action switch Select whether to check shapes and combinations, smooth shapes, or smooth shapes and combinations. Check shapes and combinations: check all the selected shapes in all possible combinations and generate a report containing the element quality for each combination.
Smooth shapes: smooth all selected shapes individually and generate a report containing the element quality for each combination.
Smooth shapes and combinations: smooth all selected shapes individually, and then smooth each combination, optimizing them for element quality. A report containing the element quality for each combination is then generated. This option produces the best element quality when shapes are combined, such as during an optimization run.
Report file Specify the name of the report file to be generated or click the save icon to select the target file. Edit checks Customize the element checks used by smooth shapes. In this dialog that opens, each of the six supported element types can be selected from element type pull down menu. Each of the seven element checks can be made active or inactive for each element type. All three element quality limits can be set separately for each element test and each element type.
Use the exclude elements selector to exclude any elements from all element quality checks regardless of the type and test.Note: The element quality settings and excluded elements are persistent, meaning that they will be stored in memory and recalled for future smooth shapes operations until manually cleared. These settings are not saved to the model file and are set to default values when a new session of HyperMesh is launched.Fix features Select which nodes will be held fixed during smoothing, which means that the node perturbations of shapes at those nodes will not be affected by smoothing. Edges & feature lines: fix all of the nodes on the edges of the mesh along with all of the nodes lying along feature lines on the external faces of solid elements. Feature lines are determined using the specified feature angle.
Edges: fix all of the nodes on the edges of the mesh.
Edges & faces: fix all of the nodes on the edges of the mesh along with all of the nodes lying on the external faces of solid elements.
None: do not fix any nodes.
Fixed nodes Select nodes to be held fixed during smoothing, which means that the node perturbations of shapes at those nodes will not be affected by smoothing. The specified nodes will be fixed in addition to any nodes fixed by the fixed nodes selector. Constraints Fix: fixes all constrained nodes during smoothing. Fixing nodes means that the node perturbations of shapes at those nodes will not be affected by smoothing. Apply: apply all morph constraints during smoothing.
- Click Check/Smooth.
Element quality limits
Trias
Test Warning Error Invalid
Aspect ratio 50.000 500.000 10000.000
Skew 75.000 85.000 90.000
Minimum angle 15.000 3.000 0.000
Maximum angle 165.000 177.000 180.000
Warpage ------- ------- -------
Tetra collapse ------- ------- -------
Jacobian ------- ------- -------
The second section of the report file contains one sub-section for each combination of the selected shapes. Each sub-section will contain a list of the selected shapes and the multiplier applied to each one for the given combination. Each sub-section will also contain the value of the worst element quality for each of the following active tests: aspect ratio, skew, minimum angle, maximum angle, warpage, tetra collapse, and jacobian. The worst result for each test is measured against the element quality limits to determine whether an optimization run will give a warning or an error, and if so it will be noted in the given sub-section along with the offending element ID and the element test limits for that element type.
Combination 15
Shape 2 applied at 1.0000
Shape 3 applied at 1.0000
Shape 4 applied at 1.0000
Shape 5 applied at 0.0000
***** warning - poor element quality *****
Aspect ratio 4.240
Skew 60.303 Elem id 112 Limits: 60.000 75.000 90.000
Minimum angle 26.718
Maximum angle 158.141
Warpage 0.000
Tetra collapse 1.000
Optimization errors can be avoided using the following limits:
Shape 2 upper bound 0.9230 lower bound 0.0000
Shape 3 upper bound 0.8680 lower bound 0.0000
Shape 4 upper bound 0.9230 lower bound 0.0000
Shape 5 upper bound 0.8680 lower bound 0.0000
If you set
the upper and lower bounds on your DESVARs to these values, the optimization run
should not encounter any errors due to element quality regardless of the combination
of shapes applied.
